Mick
Will the etch be available to purchase in due course?
Doing a bit of digging re the front sandboxes it seems that the small one was replaced by the LNER with the L shaped one to fit under the tank balancing pipe. Only 7 engines had the large sandbox according to Yeadon, 770,774,775,779,780,784,785, which was apparently due to the fitting of Down's sanding apparatus. No I don't know either. 775 in 11/45 was the first one, the rest were in the BR period. Presumably in these engines the tanks balanced via the well tank, or perhaps an inboard balance pipe between the inside tank faces.
Martin
Edit: Wilson Downs of Shildon applied for a patent in 1944 relating to the application of sand by steam or compressed air. The patent drawings look suspiciously like the sanders on a modern steam or first generation diesel loco.
