Construction of structures in readiness for the new layout continues. The passenger platform was constructed far too long to make it easy to determine the required length visually. It has been shortened and the ramp replaced by a stub end with steps as at Llanfyllin. I am following this station more and more and a brick-built half-relief cattle platform has been built....
The station building has been positioned further down the platform. It will be joined by a platform-mounted signal box...
As can be seen, everything is loosely positioned. The previously intended cattle pen is now narrower and serves as an end loading platform. It has always been a dingy corner of the shed, which made Carrog look depressing in 2018. Therefore the whole set-up at this end is closer together and nearer the end backscene to allow more window light to hit the station area. There will be a shallow embankment rising up from the platform ends to the backscene and a large gate serving the end loading platform, but scenery can only be added once the track is laid & ballasted...
