7mm Corwen Road
Discussion in 'WR Action' started by LarryG, 17 May 2019.
  1. LarryG
    LarryG Western Thunderer
    The basis of a station masters house-cum- passenger facilies has been put together and trialed on the layout along with a photoshopped tree to disguise the low-relief...
    AdeMoore, Deano747, Andy P and 9 others like this.
  2. LarryG
    Someone said I would end up modelling Llanfyllin! As soon as the GWR building was replaced by the house, it looked right. The station masters house will shortly be joined by another building to provide passenger facilities. The biggy was I could find no way of justifying a so in yer face GWR architecture on a Cambrian platform.
    Some of the surplus O gauge buildings will be advertised for sale shortly. Which is why I am currently painting the Cambrian signal box built initially but then replaced by the smaller box.
    AdeMoore, Andy P, Deano747 and 5 others like this.
  3. jonte
    jonte Western Thunderer
    Great idea, Larry.
    AdeMoore and LarryG like this.
  4. LarryG
    It always seemed to me that the obvious place for an end-loading bay was off the end of the passenger platform. This is now possible since moving the platform forward away from the backscene to accommodate the station building (see WB). A section of path behind the station can also be built...
    AdeMoore, Andy P, Pencarrow and 5 others like this.
  5. LarryG
    Didnt take long to paint. Sprayed it cellulose sandstone colour. Half an hour later it was brushed over with purplish acrylic paint and left standing upright so that the paint would settle in the cement courses. Some of it was washed out under the tap while wet. The top was only partially stained becasue it will be covered with scenic ground materials...
    The cattle dock remains in brick for the time being......
    AdeMoore, Andy P, Pencarrow and 10 others like this.
  6. LarryG
    Progress so far with 3D station house and waiting rooms complete and awaiting painting. It's probably time a proper layout thread was started...
    AdeMoore, Muddysblues, Andy P and 8 others like this.
  7. jonte
    Very neat job you’ve made of the bay, Larry, and I’m dumbfounded by the rate at which you achieved the realistic weathering. Admirable.
    Ingenious too how you’ve developed a whole station building from what looked like a third of it in the low-relief kit. It looks resplendent in it’s intricate bargeboards adorned with finials. More to the point, it draws the whole scene together.
    Very nice.
  8. paulc
    paulc Western Thunderer
    Following on from what Jonte said , the goods shed doesn't look so large anymore either .
    Cheers Paul
    AdeMoore, woolv and LarryG like this.
  9. LarryG
    Your right. That was the first thing I noticed when initially trying out the building on the platform. I'll be constructing a replacement good shed soon, as the plastikard roof went all potty last week with bubbling slates and a distorted plastikard back wall panel. For what the kits cost, it is better to scrap and replace only this time it will be built without windows.
    Jonte, weathering stone work is an easy process that is just about foolproof. If only I could sort out a quick way of getting the kind of brickwork I want. Still experimenting.
    AdeMoore, 3 LINK, Muddysblues and 3 others like this.
  10. Gismorail
    Gismorail Member
    Just to echo other's comments the whole scene is looking excellent and special mention must be given to the 'end loading bay' it was made to be there 'wonderful modelling ' Larry
    AdeMoore, Andy P and LarryG like this.
  11. LarryG
    All the buildings are now in the lighter red brick...
  12. Dave Holt
    Dave Holt Western Thunderer
    In my view, they look much better as a group in the more uniform, lighter colour. Better crack on with laying the track now Larry.
    Dave.
    AdeMoore and Muddysblues like this.
  13. simond
    simond Western Thunderer
    Larry, that group photo of the buildings is really lovely.
    I had to look twice to notice the parlous state of the track :)
    AdeMoore and Deano747 like this.
  14. freelance7
    freelance7 Western Thunderer
    Larry,
    A really nice group of buildings, they go all go very well together.
    Paul
    AdeMoore likes this.
  15. LarryG
    Thanks Dave, Simon and Paul for your comments. Track has been lying around on the baseboards for some months, in fact it's been there for so long that laying it permanently where it stands now seems the natural thing to do. It is all aimed at avoiding the pitfalls of the past.
    I think at this juncture it is time to think about starting a proper layout thread with a working title.
  16. Focalplane
    Focalplane Western Thunderer
    May I add my 2 cents. If you are ready, do it!
    Paul
    simond likes this.
  17. LarryG
    Hi Paul, you won't find me working in a garden shed in winter. That's a Spring job when it is pleasant to be outdoors.:)
  18. Focalplane
    So true! Will those buildings be kept indoors each winter? I had forgotten how damp British winters can be.
  19. simond
    And British summers...
    Pencarrow and Deano747 like this.
  20. LarryG
    First thing I noticed when we moved to the North Wales coast was how quickly the ground dries following a rainfall. Nothing in the shed has ever been adversely affected by damp. Summer heat often keeps me out of the shed from mid-morning, which is why I said I tend to lay track in spring. Heat speeds up track laying when using my method of PVA, lay track & ballast in one go, while winter cold is next to useless.
    I mentioned in one thread that my elderly compressor set up packed in recently. Its replacement came two days later from Amazon and I must say this unit has been a game changer. By the time I have put my mask on the compressor is up to 25lbs. In th'olden days I used to switch the compressor on 10 minutes before it was needed to give it time to fill the large air bottle. Eventual removal of the old equipment will free up space within the shed and outside once the old brick compressor housing is removed.
    The old oufit...
    1968-2020...R.I.P
    The new compact all-in-one outfit...
    Gismorail, AdeMoore, Deano747 and 7 others like this.
