GWR Sun Class 2-2-2ST in G3
Discussion in 'G3' started by geoff_nicholls, 12 January 2021.
  1. geoff_nicholls
    geoff_nicholls Western Thunderer
    Latest pre 1860 project: a GWR Broad Gauge Sun class 2-2-2 saddle tank. Wheels from Mark Wood, power from two axle hung motors from Tim Gleed-Owen. I could face the idea of trying to power the driving axle. I do have the new book by Canon Brian Arman, but if anyone else has built a model of this or the Leo class, I'd be grateful for your thoughts on the brake gear.
    The outside frames will be non functional.
    Photos to follow
    Spitfire2865, Rob Pulham and Dog Star like this.
  2. geoff_nicholls
    First test run on a 1 metre test track. It's a bit nippy on its own, and quite free running. Reasonably slow pulling a load.
    Very simple construction of the frames with three point suspension, using a rocking rear axle. 20210113_141547.jpg
  3. Jon Nazareth
    Jon Nazareth Western Thunderer
    Geoff
    That all looks very interesting. Can you tell me please, what sort of bearings have you got on the axle ends? Also, the driving axle, or at least the part that shows in the wheel, is of a larger diameter than the trailing and leading. Is there a shoulder for the wheel to locate against or does it have something to do with the bearing?
    Jon
  4. geoff_nicholls
    The bearings are something I found online, I think they're what's known as oilite. I still have the invoices somewhere. The Apple Tree railway gearboxes on the outer axles need a 5mm dia axle, the central "driving" axle is the G3 standard 1/4" with square ends. All wheels are fixed on with allan screws (like Slaters). The wheels are from Mark Wood, Walsall did the machining and axles. the drivers have 1mm vertical play.
    rosspeacock and lankytank like this.
  5. Jon Nazareth
    Geoff
    Thanks for the reply. I think that I understand although, I can't see that the ends of the axles are square. Were the Oilite bearings flanged when you bought them?
    Jon
  6. Ian_T
    Ian_T Active Member
    You can purchase both flanged and plain (e.g. un-flanged) versions Jon - in all common metric and imperial sizes.
    They are also called 'Oil-filled Bronze Bushes' - Oilite being a brand name.
    Google 'Simply Bearings' or ' Bearing Boys' - I use both companies and their delivery and quality are excellent.
    Regards,
    IanT
    geoff_nicholls and rosspeacock like this.
  7. Jon Nazareth
    Ian
    Thank you for that, I'll look them up.
    Jon
