Hi Julian,
Thanks very much for your comments, much appreciated.
I used 151 glue to stick down the bits of copper clad, holding gauge doesn't seem to be a problem, but in one or two places the template is lifting, I propose to sort that, by soaking the area with superglue in the hopes that will cure the problem.
As for motive power, I have a number of kits to build from various sources and some part built kits that I have acquired from other sources. I have also acquired a converted RTR 57xx, which although out of my time period, will be pressed into service to get the track tested. I hope to get all the buildings paint shop ready and the wagons also. I can then clear the baseboards and set about fettling the track and testing it.
Thanks.
