LarryG
Just an update on replacing my old DeVilbis spraygun. It has served my business well in use almost daily, and it looks it!
A comparison between the Sparmax GP50 and GP850 airbrushed with triggers. A top-mounted large cup is what I am used to. An air hose with 1/8" connector is required for the Sparmax guns...
The GP50 nozzle. The cup is side mounted. I found it prevented me seeing the nozzle. Also the cup could swivvel on its mounting if not kept screwed tight. The contents of even the larger cut were insufficient for spraying an 7mm scale model...
The more sustantial nozzle on the GP850. This is the round shaped one. It also comes with a fan shaped nozzle. This gun also has a stronger spring so there is more resistance on the trigger ~ which is similar to my old Devilbis....
