Well that aged well.Good to see you getting chance to do some modelling Adrian.
Pressures of work and other issues just left me drained in the evening so I never had the energy to pick this up. However just before Christmas I decided I had to get moving on it again. A few recent posts have shown a little more interest in pre-grouping and Precursors so I thought I would post my updates over the next few weeks.The front, middle and rear parts of the side frames were clamped together with tool maker clamps and using a ruler across the top to make sure they were straight from front to rear before soldering them together. It was only at this point did I start to appreciate how damn long this tank loco is going to be!
I then set about making some more of the intermediate frames spacers. Also behind the buffer beams a mounting plate to enable the bodywork to be attached to the chassis.
Also additional brackets for behind the buffer beam - cut from a strip of nickel-silver, riveted along the edga and then folded.
Once all the parts were ready I started soldering together the chassis - no photos I'm afraid of that stage however no complex jigs used. It was assembled on a flat glass plate and as the hornguides were fitted rather than "alignment axles" I just used two length of brass square bar and careful checking with an engineers square.
