john lewsey
Hi Jonte, any news on the Precedent?
Hi, I am pretty sure that Locomotion models have them .
Jonte,
I think that picture is the real thing posing as a model.
Jon,
I may misunderstand your question, but don’t ever have a hard stop on a servo - rather like an unruly toddler they get very cross, and push as hard as they can if they are not allowed to go as far as they want.
an alternative - arduinos and servos work quite well together.
best
).Ok, I had misunderstood!Hi Simon and many thanks for sharing.
It’s probably my ignorance of the subject which has confused, but these ‘drivers’ as I call them appear to be a series of resistors and other components on a relatively small motherboard, replete with several metal squares that have buttons in them (or at least for controlling bouncing semaphores). Essentially, say with a semaphore signal, the control wire goes from the balance weight to the servo arm. The servo is then connected to the motherboard as described. One button as I recall is used to set one end point by moving the servo arm one way to the desired position (arm ninety degrees to post) then another is pressed to move the servo arm to the up or down point depending on whether upper or lower quadrant. The other buttons are used to control the amount of bounce required in between although the driver operates them randomly like the real thing (see my video somewhere up there).
Essentially, I only require the end point buttons for what I have in mind for the uncouplers and these seem to be offered by the Pocket Money kits if I’ve read the article right.
Still, Simon, I’m open to any suggestions that an ignoramus like me can understand so I’d be delighted to learn a little more of that’s okay?
Many thanks.
Jon
You would be better off using the Servo 1 kit (kit 77 or 77R). There are two options: one for points and one for signals. The option for signals gives you the ability to have "Bounce".Jonte,
The MERG PMK servo drivers do work, but it takes some fiddling to get them set up, I've used them on Dapol signals which had given up the ghost.
Thanks, Phil.
Did you use the end points of the servos to achieve a ninety degree angle to the post (and if so was there any droop?) or was there a ‘stop’ on the post for that?
Were you satisfied with the results, albeit a lot of fiddling about involved, or was it a case of never again?
Hope you don’t mind my asking.
Best.
Jon
Btw: I note Clive at Heathcote supplies an uncoupler which acts like what I’ve in mind, but don’t want to bother him too much at present due to his current unfortunate circumstances.
I’m too tired to read about electickery tonight, I’ll catch up in the morning, but glad to hear you got your Precedent sorted and that photo looks a real treat.
your approach of using a servo controller, and setting the endpoints on that is perfectly fine.
I was concerned that you were going to have a mechanical stop to set the servo travel endpoint. That would generally end in tears (and maybe smoke).
