Rob Pulham
Looking good Mick,
I definitely need to get the interior kit for mine.
The first pictures show the finished MMP underframe detailing with an addition from me of the plastikard pockets to hold the W-irons. This was done so that the wheels could be removed for painting and I also didn't want the working springs to get clogged with paint. The next picture is of a wagon treated to some Halfords rattlecan black and you can also see the lead added for the extra weight needed. MMP recommend an overall wagon weight of 250g to acheive correct running with the working springs, however i've crammed as much in as I can and they still only weigh in at 220g each. So i'm a little worried about how they'll get on ? The remainder show the weathering effects and the door chains and brake lever pin and chain added. The chain was recommended by Steph some time ago and I'm quite happy with it. I prefer it to twisted wire even though it's still a little over scale for these. Fingers crossed for the test run tomorrow at West Mersea, even if they don't run well I'll get some photo's of them in an overgrown siding and they should look at home there
The sun was shining, but no running unfortunately. It was good to see your wagons in the flesh though. Excellent work![]()
Hi I've just been reading your article in MRJ it's really good . I've just spent a couple of weeks scribing and drilling the inside of some POW wagons only to discover that some one makes etched insides . I've ordered some
Nice wagons
Hi Mick,
Just had a read through your workbench thread, very impressive.
I see you work for the police at J41, do you know Neil Hollis?
Warren
Hi Mick,
What with the details of adding MMP etches to Slater's kits in this thread and with the recent MRJ article I guess that there is going to be a number of WT members who will be tempted to try the same route to improved appearance etc. of kit-based POW model (see post from John a few posts up). Seems to me that you might be receiving questions about using the MMP products hence you may feel that setting up a new thread "Mick does MMP" is a good idea... and could then ask the Flying Squad to move appropriate parts of this thread to a new home.
Whether you do or whether you do not, I wish to ask a question. The working bearing springs are made from separate leaves and you have noted that blackening each individual leaf helps when soldering the leaves into the spring buckle. What do you do when you get to painting to ensure that the springs get some colour and not enough colour as to gum up the works?
