7mm On Heather's Workbench - small and perfectly formed
Heather Kay
Richard, I still need to call you. It completely slipped my mind over the weekend.
Easing back into the workbench, with a view to finishing this loco so I can start weathering. Here is a shot showing the cab details.
I have fitted the buffers properly, and the couplings. The front buffers needed the threaded end chopped back a bit to avoid fouling the sandboxes. The crew are glued in, and the glazing fitted to the spectacles. Now I have the right transfers for the tanks, that's pretty much the final details.
Ah, yes, re-engineering the coupling rod joints…
Heather Kay
I love the handbrush Heather, not something I have seen modelled before:thumbs:
Thanks Rob. It's part of the set of tools and bits you can buy from Heroes of the Footplate. I reckoned the cab is too small for a larger brush, and a hand brush would be ideal for keeping things spick and span.
Rob Pulham
Thanks Heather, I wasn't aware of those - there is quite a variety.0
I have a few sets of the Peter Roles tools in stock but apart from a shovel they are mainly hand tools, although I am rather taken by the tea billy. I would have posted a link but the site doesn't seem to want to load at the moment.
Very nice, a stunning bit of modelling - well done. I like the little details like the bent wires on the rear spectacle plates and the insulated pipe along the footplate is very very effective.
As usual the photo's are a cruel enlargement of any issues so please don't take this the wrong way. The only thing I'd say as a suggestion is to trim the length of the crankpins, I think that is the only thing that stands out for me and trimming that back close to the crankpin nuts would finish it off perfectly. So as I say a brilliant job and I hope the customer is satisfied!
Heather Kay
Hi Adrian.
Yes, the crankpins (and the joining rivet) still need to be sorted out. It's on the cards for today's session at the bench. I also need to weather the frames a little.
EDIT: I am collecting a MetalSmiths rolling road at Reading in a week or so. Until the loco's had a proper running in session, I plan to leave the crankpins at full length - just in case. I will sort the knuckle joints out, though.
7mmMick
Fantastic work Heather, any chance of a view of the rolling road on arrival as I'm in the market for one :thumbs:
ATB Mick
