3D printed track was exhibited at Scaleforum earlier this year, but the results were nowhere as good as the photo above.
Which makes me wonder; are there consistency issues with the process or were there issues with the exhibited track that were to do with that exhibit?
@David Mylchreest
Hi David,
I don't know what was exhibited at Scaleforum. The turnout in the photo was available for viewing at Scalefour Crewe this year.
The results from 3D-printing can vary wildly according to which 3D printer is used, what nozzle size is used, what filament is used, what profile settings are used.
I have posted repeatedly what I used to create the turnout above. Anyone who does the same should be able to get the same results. They are repeatable for me on two different A1 printers.
1. STL file created by Templot set for COT track (rails slide-in) and the rail-section in use (above is EMGS code75 bullhead nickel-silver).
2. Bambu A1 printer, fitted with 0.2mm nozzle.
3. PVP glue-stick used to give good adhesion on build plate.
4. Bambu PLA Basic filament in grey. Filament never exposed to air for more than a few minutes. Transferred from a new sealed package to a sealed reel feeder containing desiccant:
Fully dried filament is important when using a 0.2mm nozzle and thin layers. Results with filament which has been exposed to air for any length of time will be poor, especially at this time of year.
5. STL file from Templot mesh-fixed and sliced in Bambu Studio software (free). Before slicing I rotate the part on the build plate so that the track is running generally in a north-south direction. This improves the dimensional accuracy of the track gauge and the rail-fit, but doesn't affect the actual appearance.
I set the highest available quality with 0.2mm nozzle, which Bambu call 0.06mm Layers High Quality.
I then make the following changes to that: 1st layer height 0.18mm. Infill density 40%. To save time I use the
height range modifier function to increase the layer height for the timbers to 0.12mm, up to 0.4mm below the timber surface. Finishing the rest of the timber in 0.06mm layers gives crisper visible corners on the timbers. None of those changes affect the quality of the chairs.
(Sunlu PLA+2.0 filament in Oak Wood colour works equally well with the same settings, and Bambu filament setting, and is cheaper.)
Bambu A1 printer:
Bambu Lab A1 | Multi-color 3D Printer
I can't answer for what happens if you use a different printer, different filament, different conditions, different settings.
For more information please ask on Templot Club forum.
cheers,
Martin (no connection with Bambu).
