So, the P4 is now completed. I could have done more, particularly to the engine and rear suspension, but I've achieved what I set out to do and considering the quality of the base model, I think it now looks a pretty reasonable representation of a Farrari 330 P4 Spyder. Here's a walk round of what it looks like now. The front clam does not sit down as tight on this side as it does on the right, but I didn't spot that until after the painting was done and I aint messing with it now.
The original Ferrari logo on the front clam was way too large and has been replaced with one of the correct size.
It took a lot of fettling to get the front light covers to fit as well ax they do, but they are still far from perfect.
That little domed vent above the oil filler cap was the only one I could drill out, so I've painted the front edge matt black to give an impression of an opening.
As I said, a lot more could have been done in this area but I'm still pleased with it and it's a big improvement on how it came. I'm particularly pleased with the bungy cords retaining the spare wheel.
The silicone tubing used for the brake cooling pipes should really be ribbed and I managed to achieve a reasonable representation by coiling copper wire around and glueing with cyano. However, the silicone tube doesn't take paint very well and it tends to flake off so I decided to just leave it bare and unribbed.
Here's the gubbins under the front clam.
And the cockpit. The steering wheel, rear view mirror, gear lever and gate were all scratched up from bits of brass sheet, rod and copper wire. Not visible in this shot but the dials have also been added to the instrument binnacle. They were black on the real thing but I had some white ones and decided to use these instead to make them more visible. The door hinges are piss poor but there was nothing I could do with them.
Looks better with the doors closed.
The seatbelts are 1:20 Tamiya items. Scale wise I think they look OK but they are from the 1970s as that's all Mr. Google could find for me on t'internet.
This view from the side gives a better view of the gear lever, gate and seat belts. The gear lever knob is the original after much spinning in the mini drill to turn it down. I think if the original was scaled up it would be twice the size of a tennis ball. Since the last post, I mixed up some red and yellow Tamiya paints to give a closer match to the car body colour and then re-painted the seats.
The cantilever windscreen wiper has been cobbled together from some bits from single arm etched wipers and brass wire.
Cheers,
