Thank you very much Geoff, actually I'm feeling less gloomy about the time taken as it was only 4 years ago last June that I started
Anyway, I have been cutting away part of the rainstrip and body side of the two cabs so that the side will butt up to the cab casting. Having got one side sort of done I have just stuck the "floor section" along the bottom edge of the side and set it all up in position with the cabs to check that the angle is right.
Needless to say there are "issues", most obvious being that I have made the gutter beading sit too low to properly match that on the cab casting, this is not the end of the world but will need some remedial action.
I intend to create a substantial styrene "land" on the inner edges of the cab castings on to which the sides can be glued, which will achieve a good transition between the different body sections I think.
But thinking this through any heavy work on the cab castings will need to be done before the body is assembled. I suspect my method will be to make a "kit" of five major components, two ends, two sides and the underframe which each locate with each other hopefully enabling correct "fit" to be checked. And the roof too I guess, although I intend that this will be removeable.
I may unclamp the second side and glue the strengthening strip on tonight before retiring.
