Trade 7mm laser bits and pieces
Giles
In a very small, kitchen table fashion, I am producing small items for detailing - mostly in 7mm, but can be available in other sizes (practicality allowing!)
Packs include:
Drain Grills (cast iron)
Round Drain Covers (2' dia.)
Gutter brackets
Down-pipe brackets (two sizes)
Cable brackets (two sizes)
Nuts (not threaded - obviously!) 1.5mm AF, and 1mm AF
Bolt heads - as above
Fires Escapes to order
I have little Web Page. Www.bygiles.com
Scale7JB
The products on your site look great, need to have another look to see if anything is required..
JB.
Giles
I try my best, Steve!
Frankly, these are so small, I wish you all the luck in the world using them! I really think this is about the limit of the technology. In order to be practical, I cut them so they are just retained on a carrier, as if they were loose, they would be completely impossible to handle, and would get over-cut. This means you just push each one out as you need it.
