It has been quite some time since last updating this thread. The “Works” has not been idle but I took the decision to only report on builds of kits which are “new” to me. However here are photos of my more recent builds. First the N1 now weathered and at work on Heyside.
Secondly the Chowbent Patriot has been painted by Paul Moore who kindly provided this photo
Work on my Finney West Country has slowed somewhat but it is now back on the workbench although I will not be reporting on progress. There are far better build descriptions of these kits elsewhere on Western Thunder.
An entirely new build for me is an Albion Models ex LBSCR E1 0-6-0t. I have been looking for one of these kits for some time. When one was offered on the Gauge 0 Guild site complete with wheels and motor it had to be mine. The kit is quite old and the instructions clearly state the etches have been blown up from 4mm and there could be some discrepancies. As usual the build started with the frames and these photos show the basic components and the frames built up, on the chassis jig naturally.
Very quickly one of the discrepancies appeared in that the left leading bearing had to be moved about 1mm forward to achieve a correctly aligned and smooth running chassis.
Attention then moved to the running plate and body construction. The kit is intended to build the E1 0-6-0t but etches for the D1 0-4-2t are also included. This caused confusion as unfortunately the person from whom I purchased the kit had separated some of the etches from the main etch which had the identification numbers. Trial and a considerable amount of error resulted but eventually the basic running plate and cab were assembled.
Next to be tackled were the side tanks. Construction was relatively straightforward but as was later learned putting the tops of the tanks in place was a mistake. Inevitably they got in the way when putting the boiler in place.
The kit has only minimal white metal detailing parts and small 3 feed oil boxes were required and are located on the front of each tank. I used two castings from my spares box and added pipework before putting the tank sides in place. Trying to do this later would have been very difficult.
A piece of brass is supplied for the boiler and has to be rolled to size. Fortunately, the dimensions were within 50thou in length but could have done with being about 1mm wider. Having rolled the boiler and got it soldered up and to size it was tried in place. Unfortunately, the D1 smokebox saddle had been used by yours truly. This led to many words of basic Anglo Saxon before the error of my ways was noticed. An overlay is provided for the smokebox and of course I had made it fit the smaller saddle. Well, it is correct now but about 3 hours of wasted work has resulted.
The build has now reached this stage. Lots of cleaning up to do, no invisible soldering here! A number of the white metal fittings must be used but I intend to replace as many parts with lost wax castings where possible.
