Julian,
I believe CPS Models purchased the rest of the Zero Zephyr range? As they make note of it in the link below.
CSP Models - 7mm Kits
Paul
Correct obviously but l didn’t know if they’d announced it yet!
Julian,
Paul
I could be very tempted with one of those standard gauge Simplex kits. Although there's mention of a few narrow gauge versions being converted to standard gauge, I don't think I've ever seen a picture of a converted one. The only standard gauge pictures I've seen have bigger wheels and look quite a bit different.
I still fancy getting one though!
Interesting, I can't find any pictures of an NG to Std G conversion either.
The two main publications, Motor Rail Ltd by Keef (Lightmoor) and The Early Years of the Motor Rail & Tram Car Company by Davies, (Plateway) offer the information that post-war standard gauge conversions of the surplus WD 40hp locos were supplied not by Motor Rail (Simplex) but by various others including Kent Construction (Planet) - the only picture I can find (attached below) comes from a circa 1925 Kent catalogue and shows a very similar underframe to the post-war std gauge Simplex model with what looks like a NG armoured body:
An IRS article describes their 8T standard gauge as having armour plating (sensible re-use of surplus armoured bodies providing weight for traction).
"Planet" Locomotives
Later examples had cast ends similar to the Simplex.
So the subject of the kit under discussion may or not be a Kent Construction conversion but not a Motor Rail - in any case like you I like it, so much so that there is now one less ZZ kit remaining![]()
Just in case it's not immediately obvious, lurking behind the steam loco on the right.Thanks for that David , and I now recall I have seen a picture of one before - indeed that very one!
Sellafield No.3
Sellafield No.3
My post above is not correct - Davies's book does mention some converted by Motor Rail by simply regauging wheels or using new axles (including for Italian Sate Railways, Leeds Sewage Wks and a Trinidad sugar refinery).
WT field trip?Right that’s it then - I’m scrapping my entire modelling plans and am modelling a Trinidadian sugar refinery!!!
I was at Duxford and can supply this to 'answer' the question above.
It is in the Land Warfare Hall and appears to be sat on 2ft track. It was very dark under the loco and 15 yards away so the wheels couldn't been seen.
Is it the same loco?
