BR Herring (Cambrian)
Time for something different (I'm waiting on the delivery of buffers for the Herring) before I fit the steps and haven't been in the mood to concoct fancy vacuum pipes, well, not yet. The underside door gear has been added and all is pleasantly 'busy' down there.
A new wagon project comes in the form of a Hornby BR standard brake acquired for a fiver in their pre-Christmas sale. The rather exciting livery that I've abused will be replaced by more sober bauxite. The body moulding came with a representation of a plywood veranda end (an in service replacement) rather than the original planking. The ply replacements seem to have been a bit later than the period I work on* so I've done the extreme thing and cut out said end panel. It will be replaced with some scribed plastic sheet reasonably shortly.
I won't be doing nearly so much to the underframe on this vehicle since with all those footboards and things the detail can't be seen so outer brake yokes and safety loops only. I've moved the brakeshoes out a bit, spaced out from the solebars with a bit of 60 thou' plastic and trapped it in with some more for added security. The brakeshoes, by the by are grey styrene, painted black. The chassis moulding is self-coloured. Hornby, with their various farcical attempts to reduce production costs, detailed, decried and sycophantically defended over there have missed an easy win.
Oh, and the lamp irons at one end have gone - these will be replaced with Masokits brass ones which will carry the lamps themselves. The plastic ones would have done, but I went and dropped the body...
* That said, re-sheeting could be quite extensive in the mid-60s, witness this LNER-built van:
