Andrew Thompson
This build was first started on the old RMWeb .The kit was purchased at Kettering 09 and the last post was Aug 09 .I had just cut and shaped 4 glass cab windowsreens . However having taken acritical look at the loco I wasnt happy with some of the fit and soldering . So I have been tinkering with grills ,door fittings etc . I am not entirely happy with the door inserts as excess heat has desorted some and I might end up soldering small brass wire around the windows instead. I have now made a start on the cab roofs and used the whitemetal fittings .I had to remove part of the sides and fronts to get them to fit . One I have started to file down but have taken to much off .I added some whitemetal solder to replace what I had removed . In retrospect I will now use Davids Isopan to finish off on both ends . One end I havent touched . ( Pictures attached).Once smoothed down will afix the buffer beams .I intended to use the whitemetal casting supplied with the kit for the front but wasnt happy with the detail and sanded it down (see the RMWeb picture) . I will now start a fresh with plasticard and detail with a mixture of brass and plasticard.Looking at the photos ,It will be alright on the night . :lol:
[attachment=5:1stkyxhd]winter 015.jpg[/attachment:1stkyxhd]
[attachment=2:1stkyxhd]winter 018.jpg[/attachment:1stkyxhd]
[attachment=3:1stkyxhd]winter 017.jpg[/attachment:1stkyxhd]
[attachment=4:1stkyxhd]winter 016.jpg[/attachment:1stkyxhd]
[attachment=1:1stkyxhd]winter 020.jpg[/attachment:1stkyxhd]
[attachment=0:1stkyxhd]winter 022.jpg[/attachment:1stkyxhd]
Will post more once I have tided up .
Andrew
Andrew
