I thought it was about time to install the check rails on the points but then I hit an obstacle, well not actually me, it was the tram loco. The old Lima chassis uses very coarse wheels set at about 28 something BBs and was not able to negotiate the point. So out came my trusty Vernier gauge and I eased the wheel sets out to closer to 29mm. I could have gone further but I think they are splined on. Only pushed through the crossing but will try power later.
I was brought up on trusty old style caliper gauges, and like the tram would not part with this set. A very versatile measuring tool and accurate enough for 7mm FS I thinks.
Trouble is I measured the track gauge at the crossing on this old point and somehow it is closer to 33mm. My turned gauges must be oversize or when I built these points I did not allow for the slightly thinner rail section. Something I have learnt along the way is you cannot keep re heating the copper clad sleepers too often as I have done, so the gauge will have to remain.
Lessons learnt.....
Julian
