Today, after a phone call to Mr Sharp, I continued with the rear steps.
Firstly, part 354, which isn't referenced in the instructions, is folded up. Open the hole slightly to take the cusp off the etch.
A 8BA bolt is inserted into the hole.
Part 354 is now located in place and tabs twisted.
I found it necessary to file the head of the cheesehead bolt so that it isn't held too tightly. Make sure it will turn. The bracket retains the bolt and should make life easier when fixing the body in place on the frames.
After the footsteps are added to the bracket, half-etched overlays with rivet detail are added to the bracket. As this is a Horwich engine build, these were countersunk on the prototype, so some judicious filing took place. Here is one of the pieces so modified. I know, it looks like a scrap piece of etch....lol.
Finished steps awaiting a clean up.
Attention then turned to the firebox, which has been short of a couple of clothing bands for quite some time. The band near the foundation ring has now been soldered in place. This has had virtually all the etched rivets removed (filed off) leaving only the bottom four, although this photo shows part of one remaining....file out after this posting!
The band was then carefully drilled at the top for the cleat which was a tight fit in the holes, and also then soldered in place.
