Bethesda Sidings
Discussion in 'Entries' started by Captain Kernow, 25 April 2017.
  1. Captain Kernow
    Captain Kernow Western Thunderer
    I'm not a DCC user, Larry, but there is a bit of room within the loco body and I've also removed the weight from the bunker (to ensure that I could glue the cab sections back together, although I will probably replace it with some lead in due course).
    LarryG likes this.
  2. Captain Kernow
    The hills behind Plantagenet give some idea of the gradients all locos working back up the light railway face, when they leave Bethesda yard:
    [​IMG]
  3. Captain Kernow
    Further progress on the 74XX chassis as of yesterday:
    [​IMG]
    Today I fitted the twin-beam compensation and finally had the wheels and axles sitting on the compensation system, as they are designed to do:
    [​IMG]
    [​IMG]
    Muddysblues, 3 LINK, P A D and 8 others like this.
  4. GrahameH
    GrahameH Western Thunderer
    Very nice work there CK, from your photographs it looks as though it will make the original look and run better.
  5. Captain Kernow
    Waiting for traffic to arrive off the Vale of Radnor Light Railway:
    Muddysblues, GrahameH, 3 LINK and 7 others like this.
  6. Captain Kernow
    Further work on the 74XX chassis involves putting the brake gear together:
    [​IMG]
    [​IMG]
    Thanks to very clever design by High Level, the brake gear is designed to be removable for painting, maintenance etc.:
    [​IMG]
    Muddysblues, GrahameH, PaulR and 11 others like this.
  7. Captain Kernow
    I've found it necessary to reduce the width of the High Level gearbox, that comes as part of the kit. It's already quite a narrow gearbox, at about 7.5mm or so, but even that wouldn't fit between the brass bearings on the driven (rear) axle:
    I first of all removed one of the gearbox sides and re-fitted it about 1mm further inwards, using some 10BA bolts and nuts to hold it in the right position for soldering:
    When I was happy with the alignment, the side was soldered back onto the main gearbox and some additional strengthening pieces added:
    The gearbox now fitted!
    Now waiting installation in the chassis and test running etc.:
  8. AJC
    AJC Western Thunderer
    Nifty work, Tim. Presumably this is primarily because you're working in OO here? I've done something similar a couple of times (for the same reason) in EM to get the hornguides in on my Gibson O2. Even then, I had to make the bogie compensation beam ride on the boss of the gear! Works though.
    Captain Kernow likes this.
  9. Captain Kernow
    Hi Adam,
    Yes, you are entirely correct, the problem only arises because this is being built in OO. If I'd known prior to soldering the hornblocks in place, I'd either have sought out some of Chris's slimmer bearings (I may even have some somewhere!) or at the very least, filed the normal-width bearings down sufficiently.
    john lewsey and AJC like this.
  10. Captain Kernow
    Did a bit of test running with the 74XX on Bethesda Sidings this afternoon. The motor is wired directly to the controller, hence the 'wander lead', as I haven't fitted the pick ups yet. I've also removed the brake gear to facilitate the test running:
  11. john lewsey
    john lewsey Western Thunderer
    That runs nicely Capn
  12. Captain Kernow
    Thanks, it's still on the rolling road as I type this, 'just another half an hour!'
    john lewsey likes this.
  13. Captain Kernow
    It's almost finished, after a few extra angst-ridden sessions trying to get it to run consistently smoothly and agonising about the pick ups.
    Work remaining to be done on the loco body (apart from painting and weathering) largely consists of adding to top front lamp iron and reinstating the rivet detail around the cab roof area, that was lost when it was being converted to a 74XX (this will be done using Archers transfers), plus the vacuum and steam heat pipes:
    [​IMG]
    [​IMG]
    [​IMG]
  14. Captain Kernow
    Here's some footage, complete with tinkly music:
    cbrailways, Neil, chrisb and 2 others like this.
  15. Pencarrow
    Pencarrow Western Thunderer
    When are you painting it lime green and putting a face on the front CK?
    Captain Kernow and john lewsey like this.
  16. Captain Kernow
    Would you like me to paint your face lime green, old chap?
  17. Pencarrow
    You first old fruit.
    Virtually and all that...
    GrahameH and Captain Kernow like this.
  18. Captain Kernow
    In case anyone hasn't seen these on RMWeb, here are the videos I took of Bethesda Sidings last week, in connection with the RMWeb 'Virtual Taunton Members Day' last weekend.
    1) 14XX shunting the yard -
    2) Pannier bringing local goods in and interchange with light railway J72 -
    3) Diesel sequence, with Class 14 bringing local goods in and 'Planet' diesel shunting traffic for the light railway -
    4) Military train arriving with 3F and Army loco shunting yard -
    Pencarrow, cbrailways, PMP and 9 others like this.
  19. PaulR
    PaulR Western Thunderer
    Brilliant films - excellent stuff Cap'n!
  20. Captain Kernow
    7418 is nearly ready for the body to be weathered. Axle nut covers still to be fitted:
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    [​IMG]
    Muddysblues, LarryG, Simpas and 7 others like this.
