Muddysblues
Hello Geoff, yep still oozes atmosphere and is still very much inspirational modelling, and you prove that less is more with your skilful modelling eye and attention to detail.
Craig
Craig
Thanks Larry, you are right about the amount of detail that can be modelled, which goes some way to compensating for the small size of Bleddfa.Terrific stuff. There is much attention to detail; well worthwhile in 7mm. The big draw for me in 7mm was always a 14xx tank, but a decent 14xx has at last been promised in 4mm scale.
This is all highly inspirational Geoff; a really charming and beautifully rural creation ;-)
Nice, I do like the lifted and truncated siding.
As an idea could you have left the old (rotting?) crossing gate posts in their original position and have a newer set with the original gate in the revised location to provide a bit of juxtaposition between the old and new?
If you were going to install cattle grids (or not) then you would need new fencing (concrete posts with wire or tube?) from the new crossing gates to the original crossing gate location. Again this would provide an old/new comparison and evidence the line and locale has evolved/developed. It will also allow experimentation with differing degrees of ageing and weathering without the uniformity often seen on layouts.
Craig
I wonder if Dapol designed the weird 14xx for Hattons. If so, they already have a darn good body.
With apologies to Geoff, I'm pretty certain the Dapol 14xx is all new. There's a very strong rumour that Accurascale now have the Hattons 14xx, along with the P class, Andrew Barclay and Class 66 diesel. All three of those are being produced under the Accurascale brand. The exception is the 14xx. If they do in fact have it, I suspect the chassis is being redesigned and the missing ash pan added before any announcement is made to confirm this......if in fact they bother now after Dapol's announcement.
I suspect Dapol have been working on theirs ( and the 517 ) alongside their already announced auto trailers.
I got rid of my Hattons 14xx without it ever turning a wheel, an excellent body moulding completely let down by the dome which had no flange where it joined the boiler. It stuck out like a sore thumb every time I looked at it. The renders for the Dapol model look to be ok in this respect.
Mark
Fingers crossed that Dapol don't go on to produce an O gauge 517. That would really open up Pandora's Box, as I'm currently managing to restrict my GWR modelling to 4mm scale, apart from a few O gauge wagons that I can just about get away with visiting another part of the country! I do have a OO 517 on order though, and a layout that needs it!
Dapol did that to me when they produced the K&ESR Terrier! Until then I was thinking of building a Colonel Stephens layout in EM, that may have be built by now, and had never considered O gauge, but these unfortunate things happen!Be very careful John, I was modelling in 4mm scale then bought a few 0 gauge wagons, and look what happened to me!!
Geoff
Nice touch leaving the new fence and gatepost looking new and the lighter coloured younger looking vegetation growing in the gap left by the tracklifting.
Alovely piece of work Geoff.
Wonderful modeling Geoff, thanks also for the link I was unable to watch the BBC version but found it on U tube brought back a lot of memories of the England of my childhood. Although different my train journeys from London to Manchester are still magical memories of my 7 year old self. So thanks again.
Michael
In my opinion, easily the best model railway photo in the world. Less is most definitely more.
This one is pretty darned good as well!View attachment 217588
The weather is closing in as 5807 departs for Kington Yard with a short train of empty wagons.
After much faffing about I have finally completed the occupation crossing scene which now looks something like this......
From an operational point of view shortening the siding has had no effect, as only a couple of wagons were ever stabled alongside the kilns.
The cart track narrows beyond the crossing, and its surface is slightly lighter in an attempt to make it look longer than it actually is.
With the new crossing complete, the whole area and track was cleaned prior to the line being handed back to the operating department. 5807 has been the regular branch engine for a while, and is now due for a boiler washout and exam. Or more accurately a wheel clean, lub and general check over.
Geoff
