After yet another Cobalt switch failure I have lost confidence in them and have changed over to simple DPDT switches to operate my Tortoise point motors. With the electrics sorted I made a start on the landscape, the first job was to cover the styrofoam shell with plaster bandage.
With the plastering finished the supports for the point rodding stools, cranks and compensator's were laid in place. I then gave bare baseboard top surfaces several coats of textured paint, a job that is still in progress as I build things up.
After a coat of sap / green and burnt sienna acrylics the layout began to come to life...........
The quarry branch gently climbs up to the level crossing as does the road as it passes the crossing keepers cottage. Once the railway has been crossed the road drops down again, at the same time the cinder track to the station rises. Though it is early days I am pleased how the changes in levels are working, and just how open this part of the layout is beginning to look.
Meanwhile at the other end of the layout the goods yard surface is slowly being worked up, the yard will be slightly wider, I just got careless with the green paint
The bufferstops have also been installed, the one on the left will be hidden from view by the water tower so I've used an old Peco kit. I cut the lugs that hold it to the track away and replaced the beam with a wooden one, well its a piece of card actually that has been sandwiched between two pieces of ply sleeper strip. The other is a Ragstones Models kit for a GWR railbuilt type, the castings are superb and make up into a lovely model.
Finally I carried out a colour check to see if the shades that I previously used on my 4mm layouts would work in 7mm scale. The rail is a mix of Humbrol 173 track colour and 29 dark earth matt enamels. The sleepers supporting the bufferstop, and its beam have been painted with thinned Humbrol Gunmetal Metacote then buffed up with a cotton bud. Which tends to bring out the grain of the timber and leaves that silvery grey appearance of old sleepers. It would appear that the beam was once painted white, but the paint has since faded and worn away. I made the grass tufts from Mininatur static grass fibres, and planted them into a bed of neat PVA before adding Greenscene medium ash ballast. Planting the grass before the ballast gives the impression of it growing up through the ballast rather than just being plonked on top of it.
Over the coming days I'll be soldering up the MSE point rodding cranks and compensator's and no doubt suffering from burnt fingers. The platform face is also on my list of jobs, and I hope to work the scenic's up a bit more, especially the road and cinder track surfaces.
Geoff
