Boomers Wood
Captain Kernow
Right, I think I see :) im going on the assumption that the yard is pretty much closed, but the creamery is still open and that traffic from that would be pulled back into the station.
Quite possibly emulate what was at somewhere like Hemyock in the early 1970s?
I've been following this with interest. Nice and simple plan similar to Thaxted(GER) and Leysdown(SECR). A nice uncluttered feel.
What are the dimensions of the layout? Judging from the ptotographs it looks like 3m x 40cm. Would this be correct?
Looking forward to seeing more.
David
Steve Cook
Well, I don't mind admitting that was significantly more challenging than I was expecting, and it shows in the primed article :oops: Concerning my previous flippant comment about 4mm modellers, I'd like to stand by said comment, but add 'talented' and 'skilled' into the equation too :D
The ground frame as it stands
The cunning angle of the photo disguises the issue of the badge plates gradually descending down the levers from the RHS to the LHS. Next time I think I'll make up some sort of jig to help with alignment, as is often the case, you learn the issues (and your own limitations) on the first one and improve and develop for the second. Well, I certainly hope so, but the second one is some way off yet :D
I'll let the primer dry fully, then I'll start mapping out rodding runs..
Captain Kernow
Steve,
That's one very nice job you've done of that GF.
The design of the levers and the frame is interesting - what is the provenance of the components, please, and how much tweaking have you done to them, to get them like that?
The frame looks rather 'Midland' in design, unless the bulk of the frame area is going to be below ground level?
Would ground level be where I've drawn these brown lines?
Steve Cook
That ground frame (swearing and all :D ) was well worth it Steve :thumbs:
Cheers Phill, it was rather 'sweary' :) Top of handles and levers are about 0.3mm in diameter...
Steve,
Cheers Capt'n, kind photography though :D
Its an MSE Four Lever Ground Frame (cosmetic), part number LS009. The kit blurb states that it is 'based upon Sykes and Saxby & Farmer pattern knee frames' - I suspect that will mean more to you than me :D The only mods to the kit were removal of some of the brass for the front and rear of the curved plate so it would sit flush within the sides. The corners have been filleted with solder and smoothed off.
I think there are a few options Tim, the ground could be the level of your brown lines as the instructions say 'May be used on its own, in conjunction with a ground frame cabin or recessed into a timber platform at a station or in the open'. Given its fragile nature and proximity to the joins between boards, I think a small timber platform around it so that the whole thing will be removable is the best best. The rodding can stay in situ, the join between that and ground frame hidden under the timber platform. If you have the New Radnor Branch book, I'm going to copy the image on p34.
HTH
Steve
iploffy
OC Blue Brigade
I remember the ground frames we used in Chester Depot and at the Roodee and at Saltney ferry and finally Blackpool they where all of the raised ground frame Style with the roding going out via the wooden raised frame that surrounded the metal casing around the point levers.
Steve Cook
Compensators etc. included?
Yup :cool:
Well, thats the current plan - I'm re-reading the MRJ articles and writing down the various rules that need to be applied, plus I've scouted through Tim's RMWeb blog which revealed some extra useful information (distance between stools, distance from rail etc etc :thumbs: ). Time will be in short supply this week, but we'll see how it all goes.
Steve
JimG
Yup :cool:
The first time I ever saw a good treatment of point rodding was in the series on constructing a P4 layout in the Constructor many years ago. I remember the series running for years but can't remember the name of the layout. :) But the chapters on rodding are worth reading. I'll try and dig up more details to make this information of some use. :)
Jim.
Tony West
Jim.
Would that be the Bodmin layout ??.....brilliant series, very inspirational.
Cheers Tony.
JimG
Would that be the Bodmin layout ??.....brilliant series, very inspirational..
Tony,
That's the one. I remember it as being West Country with clay traffic being a main feature. I haven't had a chance to dig out my old MRCs yet to get the dates of the rodding articles.
Jim
John D
(distance between stools)
Project Cac.......'distance between stools'......what makes me think that all this is heading down the incontinence path? Sorry , this is what comes from being married to a retired district nurse where stools are a totally different thing :rolleyes: .....and you certainly wouldn't sit on one :eek:
Old Buffer
John,
Looking at what you have just posted.
Then your signature, I am sure it should read ""constipation is the thief of time""
Alan
Steve Cook
Cheers for that. Sorry - some of us still measure in Imperial - unless the fractions get too hard...:rolleyes:
:D I'm just japing with ya, I still convert metric back to imperial when it comes to sizing things such as wood or rooms - even though I've only ever been taught metric.
Top tomato smiley btw :D:thumbs:
