Hi again Colin
things have been busy since I got back from the UK. I had 5 weeks rushing around the outback catching up on work that I had missed, then was back in Adelaide for two days when my wife went into labour a month earlier than expected. All good now though, although I haven't much time for modeling with the baby and a 2 year old. I have however started five weeks off work so I should be able to get my baseboards done.
I asked my dad today about the Carina and the Varuna and found out that while the Decima that still exists was sister ship to the Varuna. The Melissa (I believe currently based at Pin Mill) was one of 8 barges built in 1898 for Goldsmiths and was sistership to the Carina (although the Carina has a bowsprit in the photo and I'm not sure if the Melissa is currently fitted with one). So both in the Photo have existing examples to copy if you want to go to that degree of accuracy. Also to simplify things a bit you could model an auxilary barge. That is a sailing barge that has an engine installed and its rig removed or reduced. Typically they were fitted with a small wheelhouse and retained the mainmast and sprit to use as a derrick. These coversions started in the late 30s and really took off in the 40s after the war. The advantage with this is a much simplified rig to model although they look ugly compaired to a fully rigged barge. I will try to find a photo and post it in a dedicated thread on Barges. At least 2 ex-salingbarges were still trading as auxillaries when I was sailing on the
TSB Portlight in 1991.
On another note in regards to plans and drawings they do not exist for most barges, smacks etc. from 100+ years ago as they were built from half or full hull models rather than plans. My grandfather had a full hull one and I saw at least one barge of that design being bulldozed (with about 50 others + as many lighters) into Whitewall creek near Rochester in 1991, there is now a Mcdonalds on the site
I thought the model was sold some years ago but it turns out my cousin has it. I'm not sure of the scale but its probably about 1m long. It is very detailed down to the individual hatch covers having carved roman numerals but it is just the hull and deck fittings (no rigging). If you like I could have a word with him if you were keen to look at it. He is at St Osyth. When I was there in September there was 4 full size barges on site (
TSBs EDME, Vigilant, Thallata and Cygnet) plus a half dozen lighters (although these have each had an end removed so the can be used as floating drydocks).
Anyway I will start a barge thread in the next day or so and an introduction thread also so this one can go back to disscusing your planned layout rather than barges.
Bill
