BR Mk1 Limabuild coaches
Discussion in 'WR Action' started by rosspeacock, 14 February 2010.
Tags:
  1. iploffy
    iploffy OC Blue Brigade
    I am stil undecided as to what to use Kaydee's or JLTRT buckeyes I will wait and see
    Ian
  2. Ressaldar
    Ressaldar Western Thunderer
    Sidelines also do a 'buckeye' similar to the Kaydee but without the dropper wire and no draftgear, fitted in the same way as the screw link.
    regards
  3. iploffy
    Thats interesting I dont want it operational just cosmetic and ?12 seems at little steep(not that I am penny pinching)for 2 buckeyes.
    Ian
  4. Ressaldar
    Ian,
    should have said that they are about ?6.50 a pair. Hope they show up on the attached
    regards
  5. iploffy
    Sorry to wander off topic Who's CCT is that and yes those buckeyes look the part could you take another photograph of the underside where the buckeye bar goes through the buffer beam
    Ian
  6. Ressaldar
    Hi Ian,
    it's a JLTRT GUV and unfortunately I no longer have it. All I did was to enlarge the hole using a square tapered file in conjunction with a hand held drill bit.
    regards
    ps signing off now until Monday
  7. iploffy
    That looks quite tasty I think I am going to have to make representations when money permits
    Ian
  8. rosspeacock
    rosspeacock Modelling on a £1200 table.
    Westdale do a nice GUV  :thumbs: It has a one piece body which is of a very high quality with really crisp mouldings etc, probably half the price too.. :wave:
  9. iploffy
    Only 1 problem with Westdale arn't there bodies Aluminum that as I have found is hard work to get things to stick to it.
    Ian
  10. rosspeacock
    They usually are but this one is resin, Ask Phill he got one at Halifax or Kettering this year :thumbs:
  11. iploffy
    will do, do you know roughly how much he paid for it.
    Ian
  12. iploffy
    Oh by the way isn't it fun painting coaches I have tried the grey undercoat, grey ,rail blue then black for the underframes and have come to the conclusion that if you sprayed the blue first and then sprayed the grey onto of it it's easier.
    Ian
  13. rosspeacock
    I think thats how Phill did his Mk2's, I've never painted blue grey livery, how are they looking?? As for the Westdale GUV I think it was less than ?100 but I'm not altogether sure, I'm sure Phill will put us right when he next online... :thumbs: :thumbs:
  14. rosspeacock
  15. rosspeacock
    Hi all, been having a tinker with the RMB again today... Put a false floor in the middle of the coach where the floor is lower, built it up with some plastruct acting as joists also made the bar area and storage cupboard with mock "roller shutter" scribed into the plasticard, ill eventually paint all this brown to look like wood panelling and might make up some shelves and other details for behind bar area... need to fabricate some bulkheads for one end which ill scribe a "mock" sliding door into and a gangway for toilets and bulkhead for other end too... Got both Kadee's in place and operating nice and freely, next job is to finish off sanding and filling the join between sides and ends and put buffers on other end... :thumbs: Ross
  16. iploffy
    Ross where did you get the interior layout plan from as the MK1 book I have does not have internal layouts in. I am reserching the RB at the moment. How did you set the heights of your buckeyes(kaydee's) as I guess they have to be the same as the next coach
    Ian
  17. iploffy
    I have a very sneaky feeling the Cavalier coach is a Westdale and I used normal Halfords car paint but I completely fibre brushed the boby shell and degreased it before priming a bit drastic I know but it worked and nothing has come off yet
    Ian
  18. lancer1027
    lancer1027 Western Thunderer
    Looking great Ross. Whos seats are they ? I need to get my seats sorted for my RMB :thumbs:
    As regards ali bodies i have several Westdale coaches and all i did was wash with soap n water before i started work on it, and i used as Ian has ,Halfords grey primer. To fix the resin ends all i used was wilko's own two part epoxy ( yellow and purple tubes ). Before glueing them i scribed crisscross's on the edge of the resin and roughed up the inside of the ali body with coarse wet n dry :thumbs:. This process has worked for me so far.
    Rob :wave:
  19. iploffy
    This is the thing that makes no sense to me the ends of the 40ft BG I have are white metal!!!!!!!! ??? ??? ??? and you are spot on Rob Wilko's 2 pack is very good stuff got both sorts the 20 min set and rapid set and yes the inside of the ali was roughed up and I added extra support to the ends by using 'L' shaped brass section to re-inforce the joint.
    Ian
  20. Phill Dyson
    Phill Dyson Western Thunderer
    Hi boys  :wave:
    The Westdale Guv's are definitely resin & very nice they are too  8) 8) 8), I think they are about ?80'ish if I remember rightly, but you need to buy some bogies as well (I got Easybuild bogies)  :thumbs:
    With regard to Blue/Grey I painted my MK11's blue first & added the grey panel over the top of the blue once the blue was thoroughly dry..........much easier IMO than painting them the other way round  :thumbs:
    Cheers Phill  ;D
