Hello, don't know where you lot got the blue from??? Anyway I've been doing a bit more at the RMB and one or two bits on two of the CK's..... On the RMB I've done a little bit more work in the "bar" area, put some partitions in too.. On the CK's I've put tank fillers on the roof 7" from the centre line
also the water deflecting strips (should anyone overfill the tanks
) I used to think at one time that those strips were above every door..... Ive also put those things that hook on next to the buffers on a chain (does anyone know what the proper name for these is?) they put them over the buffer when the buffer is pulled out when the coach coupled to a loco, anyway done them, also soldered a wire between the buffers to stop them spinning and put the end steps on, one at each end on left as you look at the coach end on... Just look at the shape of the buffer heads (right one) from haywood railways as they come, IMHO they need filing to the correct shape, I put a 3 link coupling on at either end of each rake so just a view from underneath showing fitting etc, and re-fitted a few door handles that had got damaged with excessive handling (these were from Eileens Emporium) Ross...
