I've decided to spin the Terrier posts out of my general workbench thread - just to provide a bit more focus - the most recent post is here:
4mm - An EM workbench - Open Highs | Page 26 | Western Thunder
Anyhow, a quick summary of the current state of play:
Gradually, the loco is coming to life - it now has a full set of boiler handrails, vacuum ejector pipework (an SR retrofit - no two were alike). The smokebox has also acquired rivets (Archer's Transfers) applied over Klear and sealed with more of the same - I used a spot of Microsol to help them the transfer film sit right and the effect looks quite good but we'll see what it looks like under paint. There's a blower pipe on the right hand side of the boiler to go on and then the boiler will be painted - being a shed pet most of the pipework was burnished and will have to be added once paint and lining is in place.
Work has now moved on to the cab. The back sheet has had window bars added (fuse wire, soldered to strips of scrap etch). Most of this will be invisible...
With the coal rails added, you may wonder if that was worth the effort! What unquestionably was is the enlargement of the tool box on the back of the bunker: normal size toolbox, tiny wee loco. And yes, the slightly battered appearance is deliberate. I've also plugged the holes for the Westinghouse pump prior to adding a Gibson brass item (again, this will have to be pre-painted. And pre-plumbed). Thank heaven for transfer lining...
