No it's multiple cuts (15-20) but at 2000mm/min - this is the video showing the capability (2 mins) and making the pointer offset (5:30) and measuring and setting up Lightburn software with the offset.That’s impressive, Adrian,
my 40W CO2 struggles with more than a few mm of MDF so 15mm ply is way beyond it. Is that in a single cut?
I hadn’t realised I could do an offset from the red dot in Lightburn. A case of RTBM, I guess…![]()
I’ve tried the larger corrugated card on a 7mm test section of a Southern Traders Stores we’ve been asked to produce. This is our second largest type and works perfectly in my eyes for this building.
View attachment 203349View attachment 203350View attachment 203351
The card has no construction qualities at all. If you notice, I support the card usually with 2mm thick MDF. I’ve done so here as well. It’s the compromise one must make when designing lasercut kits or any modelling I guess. As long as it looks right and the main dimensions are correct I’m happy.
Your buildings are lovely and i would think in your hands any building made from any medium would end up looking fantastic.
Hi Chris, would that be a LSWR Type 4 signal box, by any chance?Thanks for the kind comments, much appreciated. I always surprise myself when the buildings are finished - there's never much detailed planning done and a lot of it is made up as I go. Probably why I'm drawn to the more rustic and lived in type prototypes!
Really must have a chat with you about the windows, staircase and other bits for the LSWR signal box for Pencarrow.
Sadly I shall, (oneday?) be looking for the large Type 4 and platform mounted, as at West Meon.The very same.
A picture of which is stuck behind the layout on my wall of inspiration...
I've got the pucka bought photo somewhere too.
Happy to helpSadly I shall, (oneday?) be looking for the large Type 4 and platform mounted, as at West Meon.
Don't worry Phil, you'll be my first port of call. I even have a set of scale drawings!!Happy to help![]()
Me too, and a 3d card mock up.......I even have a set of scale drawings!!
