Jordan
Mid-Western Thunderer
I keep warning about the dangers of using kitty litter for ballast...The cat is right about where I would expect to find it. Shake my head.
Hi
The station looks great I have read back
on your thread and can't see mention of it.
Is it a kit, or scratch built?
That's stunning
The railings look good, but how did you do it? How do you hold the tube? How do you stop the drill wandering off the curved surface? What speed did you use? Did you mark out the tubes or use the X-Y table for spacing the holes?Hi Guys,
I need some safety railings for my goods platform so I thought I would make some up out of some brass tube and wire I have knocking around.
Also my good friend " Grasshopper John " has just brought the same mini pillar drill/ milling machine that I have, so I thought I would show him what it is capable of.
The brass tube has an o/d of 1.2mm and the wire is 0.7mm, the drill bit I used is 0.75mm, so the tolerances are quite fine for drilling a hole through the tube.
Just the one drill bit was used, no breakages.
Martyn.
