7mm Connoisseur Models LNER N10 Tank Engine
Lawrence Boul
Thanks Lawrence,
Sadly although I do some 3D designing, I don't have a printer (or room to host one). Although I have a friend who does printing for me, he's not nearby, so it's not convenient as he needs to post things out to me. To make matters worse, we have just received notification from Royal Mail, that they are only going to deliver our 2nd class mail every 3 days going forward.
Prompted by this idea I had a go at printing an arbour with an M14 x 1thread to suit the Unimat3. It worked rather well and was true to the eyeball, though I don't have a DTI. The immediate thought here is a convenient holder to turn crankpins on cast wheels. I can handle a bit of tolerance on position as long as they are all the same.
Ian@StEnochs
Hi Ian,
I confess that I hadn't thought of turning between centres, something to consider if I need to make any bigger rings in the future. I am quite lucky in that many of the locos that I intend to make have the same boiler or smaller so my mandrel will work for all of them. The smaller ones will just need the ring tightening which I can do by hand. The N10 and no doubt most of the other tank engines only have half a boiler at the cab end so turning between centres isn't and option.
You must be much better or patient with a file than I am, my use of a mandrel was to get away from having to file (not very accurately in my case) the remaining quarter of the ring. But as ever when we start to discuss things I have just remembered that in some of my more vintage versions of kits that now reside with Gladiator there are some solid brass plain and machined tubes. While I may struggle to use these on the loco when I get to building them I realise that they would be ideal for use as mandrels
Not very clear in the photos being all brass the two that are turned actually have very nicely turned transition ring which would alleviate the need for DIY assuming of course that you can manage to attach all the boiler fittings to the heavy heat sink of a tube without melting them.
For anyone who is remotely interested, they are from the following 'kits' (left to right):
George Norton J21
07 Models N8/9 - 07 was the forerunner of some of the George Norton Range, so real ancient history.
London Road Models G5
Rob,
No lathe. A big file, 10" 2nd cut, for the bulk of the material then finished by rubbing on coarse emery cloth.
Lathe. Boiler barrel held in chuck with end supported by tailstock centre. A few light cuts with a knife tool.
If the firebox is part of the boiler then I screw a ring onto the cab end of the former and hold that in the chuck.
As most of my builds are from scratch it is easy to arrange the boilet and firebox to be seperate assemblies.
Ian.
Rob Pulham
In between messing about with the smokebox rings, I also detailed up a few of the other parts using either additions from the spares box or those that I made up from scratch.
Starting with the roof, I added the outer skin, fitted whistles from the spares box and the roof vent. The latter I attached to a strip of etch that I bent to allow the vent to be open but so that I wasn’t relying on a solder joint purely on the edge of the vent.
Then I rolled a strip of brass angle to cover the firebox to cab joint.
Then I prepared a few of the cab fittings starting with the cupboard at the back of the cab I made up a couple of door knobs
Plus a third knob for the coal space shutter.
I also fitted a brake standard from my spares box.
This is as much as can be added to the cab floor before fitting or it won’t fit past the beading in the cab openings.
Sticking with the cab I fitted the reverser and made up a mounting/fixing for it.
Rob Pulham
So simple!
Please Rob, did you do this by soldering two angles together to make a Tee before rolling; or maybe another method?
Hi Richard,
Yes, that's exactly how I did it. The strip that you see is actually the spare, which I made a bit longer than the piece that I needed for the N10. Just in case the boiler it gets used for, has a bigger diameter. It now in the bag with the spare joint rings and the mandrel.
Rob Pulham
After wrongly starting to fit a representation of single slide bar inside motion to the N10 I, resorted to drawing it up in Fusion.
Courtesy of a friend, I received the prints today and they look superb.
I couldn't resist priming a set
Then I tried test fitting it in the chassis as I expected there was a bit of rubbing down to do to ease it in but it fits perfectly.
It's not fully authentic, but it fills a gap between the frames.
