I can turn the wheels down as I have a lathe I just need to order a HSS tool which I'm going to need for some other kit built locos. My major problem is how do you get the wheels off with out destroying them?
I can't convert them until later this year at the earliest as they have to run on our FS layout "Scratchy Bottom" at Folkstone Show in October.
Marc
Use a wheel puller and a backing plate the same dia. as the flanged part of the wheel, the reason for the back plate is to stop the tyre being pulled off the centre.
When you re-profile the wheel measure the width of the flange and turn off the back of the wheel enough to leave 0.7mm of flange width. This brings the wheel width down to nearer scale width ( approx. 3.16 - 3.25 mm) The F/S flange will be around 1.00mm width.
This will give enough meat for the re-profiling tool to cut a new flange, but you will have to take some off the dia. of the tread as I can garantee they will not always be perfectly concentric to start with.
Measure all the wheel dia. first before turning and start with the smallest as I have found in the past that they are not always the same ( only fractionally but it makes a difference). I get the same problem with Slater's wheels.
The photo' is for demonstration purposes and is obviously not the Terrier wheels we are discussing, they are Heljan wheels.
Col.
