Crane Locomotives
Next step will be to add 'Southern' lettering to the sidetanks. But I really need to add a number as well. Ideally an unallocated number, but I can't seem to find any lists of Southern loco numbers to avoid duplication. Does anyone have suggestions where I might find this sort of info?
A bit late since you've gone for LSWR - though the Southern might not have relettered quickly, or just put a new number on! - but such an engine would have been numbered in the departmental series with an 'S' suffix ('DS' prefix under BR) so you can legitimately choose any number you like...
spikey faz
My decision was also aided by the discovery of an old set of Pressfix transfers that I bought back on the 1980s! But thank you for your suggestion. I'll bear it in mind if I build a departmental loco.
  • Like
Reactions: AJC
I'm a big fan of the thrift, too (and the LSWR lettering is very classy). A lovely model of a handsome thing. Bradley's books on LSWR locos almost certainly have details of LSWR departmental loco numbering - but the only example I can think of off the top of my head was Mr Drummond's 'Bug', numbered in the main LSWR series, 733.
spikey faz
Back in 2021 I posted on this thread that I'd started work on a Backwoods Miniatures crane kit. The project stalled as I was finding some of the assembly a bit fiddly. I can now admit I really messed up the crane chassis and boiler! :(
I recently pulled the box of bits out of the loft and determined to make the kit work this time, even if I do deviate a bit from the instructions.
Not a lot to report so far, but I have made a replacement chassis for the crane.
The wheels are about the right size, but the gearbox is the wrong orientation (the idler gear clouts the rails). I'm currently Perusing the High Level catalogue for a suitable replacement.
I'll need to source a replacement boiler as well to replace the one I messed up.
I'm the meantime I'm just researching the Internet for a suitable prototype.
spikey faz
I was intending modeling the crane with a fully open cab. But, it appears some vital parts that form the piston assembly are missing from the kit.:( So, it looks like I'll be modelling this with a fully enclosed cab. At least I won't have to spend too much time modelling the boiler.
In the meantime've been mocking up a chassis to see what it will look like. Motor and gearbox have been ordered from High Level.
spikey faz
Although I said I was going for an enclosed cab to make up for the missing parts, it was bugging me a bit. So I had a go at making the parts (slidebar trunking and piston) as well as a second attempt at soldering the boiler wrapper together. Well, success I think. :)
Once the motor and gearbox arrives I can work out how big/small the chassis needs to be. I may go for some slightly smaller wheels if there's space.
Giles
When I first built my 0-14 crane, I built it as a single axle drive (N20 via bevel gears), and I found it exceedingly erratic in its ability to pull itself along (although it was quite heavy due to its function). Of necessity I had to find a way of diving the other axle as well, which in my case I did by adding a train of spur gears between the axles. That did the trick, and now it will not only Drive reliably, but haul anything! The EM gauge crane drives the second axle via a shaft with opposed bevel gears
