Roger Pound
The demolition squad moved in on the old Cropsham over last week-end and disassembly began in earnest. The shunting board with the sector plate was stripped of track and wiring and then partially taken apart then re-assembled with the sector plate now on the opposite of the frame. As usual, what appeared to be a simple job turned out to require a little more stripping down of components as I had forgotten that the sector plate was arranged with the internal longitudinal support slightly off-centre in the main frame. Heigh ho - guess I must just be a masochist ! Notwithstanding the job is now done and ready for building upon.
My very best wishes to you all - more progress reports as and when.........
Roger.
Roger.
