victorianman
Hello. just wondered if anyone has converted one of these to S7. Apart from being a smidgen over-wide and flanges (approx. .7mm thick) being fine but still a little deep for the standards, the wheels are within a gnat's of being S7. The initial thought is to pull the wheels out on the axles, though I am aware wheels can revolve out of quartering as this is done. The axles (4mm dia.) are also just a little short of being flush with wheel boss on my example, and the wheels are mounted on insulating bushes. Behind crosshead clearance doesn't seem too bad, but as on the 4mm version, the crosshead is able to slop around quite a bit.
Any thoughts gratefully received.
