oldravendale
I think wormholes would be a bit on the small side. What about rabbit holes?True, but have you considered the possibility that it may not be Black Holes but Wormholes?
Brian
Hello all,
have you noticed that the part that you have lost always turns up in the last place that you would think of looking!
So I now start looking in the last place that I would think of looking, but to no avail as the part then turns up in the place that would have been the first place that I would normally start looking.
Figure that out!
OzzyO.
Many thanks Dave,Hi Rob.
I think you have mounted the driver's brake valve casting upside down. It also looks a bit low (compared with the tray over the fire hole and the washout plug) and too close to the loco centre-line. The centre of the main body (where the handle pivots) should be approximately 41" above the cab floor and 28" from the loco centre-line, although it might be the angle of the photo.
The heat shield is level with the end of the fire hole door runners, as you've got, and should be 201/2" from the loco CL.
When you come to them, the steam pipes from the manifold down to the injectors are not quite symmetrical, the LH pipe is 2'-07/8" from the CL and the RH pipe is 2'-21/2" from the CL.
Hope this helps.
Dave.
Thanks Paul,Hello Rob / all,
this drawing may help with the boiler front of L. M. S. locos, it's not to scale but it was drawn by the loco department Derby so it my be correct. It's in a book called questions for enginemen and such. They do turn up on the bay of e for some good prices.
It's a big file so you should be able to expand it to a good size.
ATB
OzzyO.
PS. if you want the full size file let me know.
Thanks Dave,Sorry. A correction to my earlier post. The device on top of an LMS vacuum brake valve is the vacuum relief valve - so probably does have a hole down the middle. I think the air to destroy the vacuum enters through the perforated front disc of the valve, where the handle attaches.
Dave.
Hi Dave, yes the 'pepper pot' is used on a vacuum system to ensure that the ejector (and/or crosshead pump) doesn't exceed the desired amount of vacuum. It is adjustable by removing the perforated cover and screwing the valve down tighter for a higher vacuum system e.g. GWR 25" over everyone else's 21". And as you say the air is admitted in to the system to apply the brakes through the holes on the front of the brake handle.Sorry. A correction to my earlier post. The device on top of an LMS vacuum brake valve is the vacuum relief valve - so probably does have a hole down the middle. I think the air to destroy the vacuum enters through the perforated front disc of the valve, where the handle attaches.
Dave.
I was working away on the back head this afternoon, filling the holes for the water gauges prior to redrilling the right size for the castings spigots when the door bell rang it was the postie with the final production version of the firebox print. I was then distracted so I will pick up the back head again tomorrow.
This was printed by Mike Hopkins @Mike Hopkins of Scale-Factor.
These show the firebox print as received with all the supports attached.
Then with the supports carefully removed. I still need to clean up the base and the cab end but I have tried the boiler on and it fits perfectly. A nice friction fit.
