Over the weekend I've turned my attention to the body, and in particular the cab. You can see from the photo in the post above that there's far less of the cab in the loco which has inspired the build. The first step was to reduce the size of the spectacles which had the bonus of moving them away a little from the cut outs which I would later cut out. Fortunately I had some plastic tube, which if I opend the spactacles out a smidge, I could glue in and shrink the opening down by almost 2mm. I filed and sanded all the ribs from the cab roof too as I will be fixing a larger overlay on top.
To help me reduce the spectacle plate evenly at each side I made a simple plasticard template which I could scribe round. It has a lip on both faces which holds it in place against the cab and bunker sides.
With careful use of abrasive discs and drums in the pendant drill I cut away the openings on the cab sides and spectacle plate, finishig off with files and knife.
It's quite difficult to see what's been achieved in the bright red plastic so I've waved some Halfords grey primer over the body to show what's what.
There'll be some final tweaking with emery but overall I'm pretty pleased with the finish and symmetry.
