Greengiant
I got bored ballasting with a small dropper so bought a much bigger one.
Being at the height the layout is, makes it more comfortable to sit down while ballasting. This was on a very hot day, the house kept the railway in shade until early afternoon.
Lifting more points to add switch timbers.
Some of the points relaid.
My track level checking wagon in use.
Signal box has been lifted and a holding plug has been put in while I add ground work up to it, when dry the plug can be lifted and the signal box planted back.
Signal box plug lifted, to the right of the Baguely is a plug for what will eventually be a fuelling coal/diesel stage. The engine shed has levitated down the line while the groundwork is done.
Working up the engine shed area.
Engine shed now back in place.
I stained the Grano Dust with this cement dye.
I got bored with ballasting, so played trains instead!
Martin
Martin
