An admission... I have not glazed a model in at least thirty years and I cannot remember what I used at the last time.
We have a MMP Class 08 cab approaching completion - the instructions indicate that the glazing material is 0.3mm thick and that the glazing is fixed between inner and outer framing (the inner frame being glued in place). I suspect that there are one or two completed examples of these kits running under WT-control and hence the questions:-
* what material is suitable for glazing the cab windows?
* where can such material be obtained?
thank you, Graham
thank you, Graham
