GN Rly Co acting Bracket Signal
micknich2003
I started this way back in January 2009, but for various reasons I was unable to finish it. Practicly the only work required was to permanantly fit the arms, connect everything up and paint it. John Brighton, who is better known for his loco's did that, and he has made a fine job of my bit of "Rough Iron". The main post is two etches soldered "End On", the bracket are homemade from sheet with a piercing saw and file. Photo attached, as it left me, and after John had complited it.
micknich2003
Mike, I don't have a clue why it was locally known as "Black Bess". I was given a couple of photo's and asked to make it. I'm sure someone living in the area could give you an answer.
