GWR standard boiler fittings
jamiepage
Sorry if this isn't the right place, but could I ask for some help regarding dimensions of standard GWR boiler fittings ?
I am drawing up GWR (ex MSWJR) 2-4-0 numbers 1334-6 after 1923 rebuild with GWR standard number 11 boiler. Googled diameters for boiler rings are 4ft 2in/ 4ft 3in which presumably equates to approx 4ft 8in over cladding, boiler length 10ft 6in, firebox length 5ft 6in.
However, the various fittings were standard parts so I wonder whether someone could point me in the right direction please for detailed drawings/ dimensions of chimney, safety valve bonnet, and dome. Also the rimmed type smokebox door - and indeed the smokebox (diameter) itself assuming it was also a standardised dimension.
I have copies of the various weight diagrams etc for these locos but would like to cross refer with known dimensions where possible to keep things as accurate as possible.
Thank you,
Jamie
