John Ross
As I have a stock of unbuilt kits, I thought I would further dip my toe into the O Gauge RTR stock by purchasing Hattons Gresley coaches.
Was a little bit miffed that living in the North of Scotland, but by no means remote having to pay £14-00 for delivery rather than the free option offered to everyone else.
As for the coaches themselves they come package in good supporting box. When unpacked a quick run over with the scale rule and they seem to measure up close to scale.
Quality wise the body work seems reasonable, flush glazed and separate metal coach handles. Only downside there is no obvious way to gain entry to the inside so vehicles will have to run without passengers.
Underframe is a bit of a disappointment. The footboards on the bogies are plastic held in place with two pins that were found to be broken off on delivery. A phone call to Hattons saw the faulty items uplifted (it took a week to travel back to Liverpool and two days for replacement to return). Sadly this one suffered the same fault plus metal footsteps on body were bent. Hattons offered another replacement and when their representative confirmed that they had had a lot of issues with this problem I declined an exchange and will do a repair myself.
Bogies are detailed, but are made of plastic and remind me of something that you found under a 1970s Tri-ang coach rather than current O Gauge models. I bought some Ellis Clark bogies to fit under a BR Mk1 I am working on and the quality of the latter cannot be faulted. Back to the bogies under the Gresley coach there is also a lot of side play in the wheelsets. One of the reasons I took up Hattons offer of a replacement first time around was that the bogie side frame had become detached and the wheelset had dropped out of place. I notice from Ellis Clark’s website that the bogies that are going to be fitted to their Thompson coaches are to be offered as a spare. When available provide they are of metal manufacture I will purchase these to replace the ones on the Gresley coach as the added weight should improve running.
Couplings are represented with a non-working buckeye type and screw couplings that come as an added extra that again had bits missing. I not certain how these can be coupled and if they can it will not be easy. Kadee couplings as a replacement would seem a good alternative, but space between coach and bogie I think rules this out. Best option and the one I will go for is Magclic swing type.
All in all coach is little below present O Gauge standard, if you are interested in purchasing one or a few. Hatton’s offer 4 grades of coach considering the changes that need to be made I would suggest going for the “D” version as these have a minimum of 3 known faults and are on sale for £150 rather than the full price of £179.
