I agree entirely, but the rope will need to be 450 mm long to let the locomotive run clear of the frog before the wagon reaches the point blades. I think this would look excessive, but this is only my opinion.
Well, 'Blackwater' (MW class K) needs a dead section less than 35 mm long if she is to have four of her six wheels on live track.
The minimum length of rope needed to shunt either of the two sidings would depend on whether the loco should haul the wagon all the way to the end of the siding in one go. If so, about 300 mm would be enough but clearly this still needs frog switching for the A6. The water column would have to go too, to work the platform road.
I have done my test runs with a 140 mm rope. This has worked, using a battery loco and with the loco uncoupling from the rope and "running round" as it were to propel the wagon along the siding. Frog switching would let me use one of my analogue locos in its place.
I could of course try to build short dead frogs on the next layout
