45609
Hi Simon,
Thanks for the extra photos and info. That all makes sense. I figured that you might have a common reference point on the horizontal and vertical copy master. Successful machining of parts is mostly about the planning the steps. I'm mostly working in 4mm scale so I have the added challenge of some very small components. So far I haven't attempted something with more than one profile plane. Where I've needed the depth I've split it into layers. But obviously you're not able to get any scallops or blended profiles with this method. I did some replacement brake gear for a Comet Ivatt 2MT recently (photos below). You don't really need 3D profile in this case but I do have some coupling rods to make soon and would like to have a thinner section between the bosses blended in/out correctly.
Cheers...Morgan
Cheers...Morgan
