The confidence is now building for the painting.
After the success yesterday with the blasting and etched priming the test structure, it was time to move on to adding the colours. In the past I have had issues with paint not sticking or pealing when removing masking tape. Hopefully the use of the blaster and etch primer will prevent this.
So I decided that the best order to add the colours was to paint the roof section beige first. I am using Army Painters products and they do a range of coloured primer aerosol cans for war gaming and this is what I used first for the top of the structure.
Once this had dried I masked this section up and using an airbrush I painted the crane track orange.
Again this is another Army painter colour using the airbrush thinner they supply.
I was really pleased with how this covered.
It also dried really quickly and only 2 hours later I was masking this up so I could apply the blue.
Now before anyone says anything, the blue I ordered has come out a bit brighter than I had expected. This is always the problem with colour charts etc. The Army Painter range however do different shades of the same base colour and I am ordering a different shade to do some more trials. As with the orange, the blue was applied with an airbrush.
What I am pleased with is the processes worked, I removed all the masking and the paint has not come off and the finish is excellent.
All we need to do now is get the blue right I then want to try spraying some dirt wash on which will also tone it all down.
So after last weekends frustration, this has been a far better weekend and some good progress.
On saying this I do have to be a realist, then main structure is far more complex than the test piece, with the boiler shop and wheel shop roof being removable it should help with access for the airbrush. The roofs can also be painted separately and are only one colour.
I think the biggest job after the blasting and priming will be the masking for each colours.
But at least it now looks like we should be able to get the structure at least, painted before Guildex in September.
Andy
