Ian Rathbone's Workshop
sjp23480
@LarryG,
Thanks for the addiitonal information - I did use Maskol for some parts, but I put it on after the tape - will have to try beforehand next time!
Its looking okay, I hope the lining will hide some of the flaws in the join between the chocolate and cream.
I tried to upload a picture, but the file was too large - I will try again later. Spolier alert - it is not up to Ian or Larry's standards, but it is my own work!
Thanks all
Stephen
Mike Trice
I am sure there will be a far more informed solution due from someone but one tip I have read about and tried is this.
Paint your first colour.
Apply masking tape.
Paint the first colour over the join in the tape.
When dry paint your second colour.
Remove tape.
What happens is when psinting the first colour for the second time it leaches under the masking tape effectively sealing the gaps, then when the second colour is applied it can no longer leach. Hope that makes sense.
sjp23480
Thanks @Mike Trice - grateful to have such luminaries (@Ian Rathbone and @LarryG) share ther techniques.
My approach so far
1. Prime with self etch primer (UPOL Acid #8)
2. Masked the body and painted the underframe (Halfords rattle can satin black)
3. Masked the underframe/lower sides and airbrushed GWR Coach cream (Phoenix Precision)
4. Masked the cream (not very well) and the underframe, airbrushed GWR Coach brown (Phoenix Precision)
5. Touched up the overspray by hand
To do:
1. Add the coach lining (HMRS) - sorry my lining pen skills are not there yet
2. Re visit any remaining overspray
3. Hand line the GWR Coach brown below the cantrail (bow pen)
4. Hand line the window droplights (planning to use a maroon touch up pen from Halfords)
5. Add the GWR emblems, numbers, etc (HMRS)
6. Airbrush satin varnish (Phoenix Precision) - will this affect the HMRS transfers?
7. Add glazing
8. Finish assembly: interior with passengers and staff, bogies and roof (all these are complete)
9. Give to my father for Christmas and hope he appreciates it!!!!!
20 days and counting!
Stephen
sjp23480
Do I remember that it's a lot easier to clean up overspray if you use gloss paints - at least for the first colour. Isn't that in Ian's book?
I don't have Ian's book, not do I have suitable gloss paint. Perhaps a coat of gloss varnish over the cream before applying the brown?
Stephen
Ian Rathbone
I don’t know if I agree with a second coat of paint after masking as this will increase the amount of paint resting against the edge of the tape. This will produce a ridge in the paint just where the lining goes.
I normally put the cream on first but on the compo it was far simpler to do the chocolate first.
Ian R
Ian R
Thanks Ian
That has to be a risk. I guess there’s only one way to find out!
I’ve not got any coaches approaching the bench in the near future, so “I may be some time”.
Fitzroy
I think a key to all this is spending the money to get a really good masking tape that combines a fine edge that seals with suitably low (but not too low) and well controlled level of tack. Looking at products that are used for masking conformally coating printed circuit boards after the components have been added to the board would be rewarding. Otherwise serious modeller's masking tape. Pound shop or general decorating masking tape shouldn't be used. And test run it on long lengths of scrap material. Just been working this with initial production circuit boards, ahead of getting a full production line set up.
paulc
Thanks Ian
I would also have thought that there would be a chance of the paint tearing as the tape is removed because you now have two layers of paint , one of which is definitely dry . You could try cutting along the edge of the tape with a blade .
A ridge line of paint can be smoothed down with fine 1000g or finer wet & dry paper .
Ref Fitzroys comment about masking tape , i use Tamiya and have never had a problem since i switched from using 'conventional' masking tape . Even the low tack variety was good at leaving ragged edges .
LarryG
Spray the second colour and remove masking tape immediately. The wet colour will settle leaving no ragged edge. I use (gloss) cellulose and so after an hour I scrape the colour join by running a knife blade sideways to ensure everything is level for my draughtmans ruling pen. Lining is also cellulose. The 'finish' (gloss, eggshell or matt) is applied after lining and insignia, followed by weathering.
Daddyman
Stephen
Or mix the gloss varnish with the cream. Seem to remember Ian didn't like that idea, but I've continued to use it without admitting it to him. ;)
paulc
Hi Larry , would this method work with other types of paint ? I ask as cellulose is no longer available in Australia because of it's harmful properties although i have always thought all paint when sprayed is harmful if the correct breathing gear isn't worn .
LarryG
Hi Larry , would this method work with other types of paint ? I ask as cellulose is no longer available in Australia because of it harmful properties although i have always thought all paint when sprayed is harmful if the correct breathing gear isn't worn .
The method I use with cellulose would work equally well with enamel paint, the only difference being the slowness of the process while waiting for paint to harden. Cellulose made my job viable seeing as the only way to make a decent living was speed.
Ian Rathbone
The beauty of lining with enamel paint is that mistakes can simply be wiped away without affecting the underlying paint, even after 24 hours, whether it be cellulose or enamel. Drying time is not important to me as I always have another job to continue or start. The maxim for lining is ‘one colour per side per day’.
Ian Rathbone
I’ve taken a break from painting during December to get on with another build for myself. This is from a David Andrews rebuilt Royal Scot kit. It went together ok but needed a lot of work filing the fire box rear edge and splasher openings to get the boiler to sit correctly.
I ignored the instructions to assemble the interior of the tender first before adding the sides. I did the inner supports first but then added the sides so I could solder them from inside. I split the coal well floor etching into three parts along the fold lines and attached them separately - perfect fit! To the front of the tender I added the coal door handles and feed water cock handles, which are always missing from DA design tenders.
Work to do, finish backhead (which needed a couple of Ragstone details), fit nearly 50 oil pipes to running plate lubricators, plus minor bits and pieces. The smoke deflectors are screw-on, in fact all the sections of the superstructure screw together.
The chassis was put together by Pete Silvester as a barter job. He builds a good chassis does Pete.
Ian R
Ian Rathbone
Things have moved on since my last post. The lubricator pipe work is complete - there were 40 pipes that I could fit. Back head done and final body details finished.
Here’s some of the pipe work - it’s fairly untidy on the prototype. Please forgive the state of the brasswork, it’s not been cleaned up yet.
Today it was cleaned up and the coat of etching primer went on -
Ian R
sjp23480
Ian R
Ian,
ApologieS if you have done this before, but can you explain your clean up routine?
I know you are in the cleanliness is next to godliness brigade when it comes to painting.
I am always afraid I will dislodge fixtures and fittings with over vigorous cleaning.
I'd appreciate you spending a few moments explaining your process.
Thanks
Steve
