The first photo of Tom Mallard’s two L&B locos. I only have the bodies, frames and cab roofs. Tom had stripped the etching primer from the bodies but provided black painted frames and roofs.
I cleaned the bodies with cellulose thinners to remove any residue from handling and then applied my etching primer, which was remarkably like Tom’s. A day later I sprayed the Southern Green cellulose that Tom provided and then, two days after that, I masked up and sprayed the black. The cab interiors took the equivalent of a day to paint - three coats of light stone above the waist and two of black below. Brushing was the only way in the confined space with all its nooks and crannies, the amount of detail within the cabs is incredible. The undersides of the roofs were sprayed.
I started the lining on the most difficult but least vulnerable parts ie, the cab front and the tank fronts. Due to the roof support I could only do the lower half of the spectacle lining with compasses, the rest is brushwork with a W&N 000 brush. There is a lot of lining on these engines and it all has to sequenced to minimise time and avoid touching wet paint. Because of the flat sides I had to wait two days before turning over for the other side.
For the frames it was a matter of masking and spraying the tan ‘twixt fire box and smoke box’. As for the buffer beams…
Finally a mist coat of lacquer gave these amazing models a unified satin finish.
Ian R
