A Couple Of Things
First up, the painted version of the tar tank.
Many layers of hand brushed Railmatch acrylics later, the white has disappeared. Just for a laugh, I’m doing this fictional tank ins fictional livery; green and black, and white for the lettering. The colours of Plymouth Argyle . I’m not going to weather it, much. Ideally, it should have some rust and streaking, but I’m not inclined to take it too far. I’ve had a very fruitful conversation with Steve at Railtec, and have ordered some 6 mm high B’s (4) and H’s (2) to sit on the three panels. As well as two 1.5 mm high SILVERTOWNs to go in the bottom right hand corner..
Seconds out, Round Two…
Another rescue job. An ex-Coopercraft O4 (OPEN A) that was built to the same methodology as this one
Post in thread 'Jan's 4mm Workbench'
4mm - Jan's 4mm Workbench
… the builder has put the ends up too high relative to the solebar - which exposes the strengthening rib on top of the solebar, and the pips on the wagon ends.
… so it was scalpeled apart, and a razor saw and file taken to the excess meat of the strengthening rib …
Instead of making a new floor, I tried a new tack, and thinned down the floor from underneath, with my trusty safe-edged flat file…you may be able to see what I’m after here..
Then it was on to the brakes. Having no clue as to the progression of such things, I decided to nix the Churchward arrangement in preference to the two shoe Morton variety of later years. Whether these wagons were ever modified thus in a batch is not understood. But this one was
Some ex-Parkside bits from the spares box are being pressed into service, and the Churchward bracketry at the ends excised…
And that’s where we are, for now. An evenings work on the OPEN A. You could say an open evening, I suppose…
Jan
