LarryG
It has been considered Mike. 7mm scale demands a lot more detail and so would involve a lot of alterations to the 4mm CAD's. My interest is purely in building some mid to late 1930's GWR corridor stock, but the idea fell at the first hurdle because I could not locate cast whitemetal Pressed Steel bogie sideframes with cast-on stepboards.Larry
You never fancied moving your work up to 7mm? By that I mean the drawings being moved to 7mm. Just a question...
Hope you and yours are safe
I will probably look at what is available in 7mm seeing as I only want one-off coaches for my own needs.
We are both fine thanks.
Larry
