I strongly support the idea of a separate S&T thread - most people struggle with signalling (as a glance round most exhibitions will soon show!) and I think much of that is down not having an easy way of asking for help. I would certainly be willling to add anything I can by way of help.
Here are a couple of my own projects. Firstly the Home Signals on my own (fictitious of course) Minories layout, based on Southern Railway practice in BR days. These signals had to be designed to deal with very difficult sighting issues being immediately outside the tunnel mouth. The single Calling-on arm is an example of how the Southern used off-the-shelf Westinghouse bits to make a non-standard signal. I had lengthy debates with my S&T friends about how the Southern might have solved this problem - this was the concensus:-
And the - slightly more standard - starters:-
Secondly, here is a fully locked (mechanically and electrically) 70 lever frame for John Elliott's (real location) Leeds City Wellington layout which is (as far as we can judge) a very close copy of how it was done on the real thing. In this case, we had the original box diagram to work to, but had to "reverse-engineer" how it was intended to work the layout and how to interlock the frame accordingly. As we are interesting in Signalling, we wanted it done "right" and we work the layout as "right" as we can. The frame and locking is built from kits available to members of the Scalefour Society.
It uses the same principle as the Great Western 5-bar VT locking - not least because it is very compact - though it actually only has 4 bars for practicality. Of course, I
should have copied the Midland design of frame, but making catch handles strong enough to withstand the locking proved impossible!
This project has appeared in MRJ recently (one more installment still to come), where I described how we tackled some of the tricky bits.
Experts will spot that a lot of creativity was needed to fit all the locking into a very tight space.
Looking forward to a new dedicated topic and the contributions thereto!
Best Wishes,
Howard
